RPM don't go back to stationary
90cruiser
Message par 90cruiser » 16 Mai 2017, 23:38
Hello you all!
My Audi has a technical problem since a week.
It did not go back in rpm. Even if i dropped the clutch.
Replaced the temperaturesensor & placed another ISV.
It goes back in rpm now but slow to 1200. If i disconnect the temperaturesensor it goes to 800-850.
What can be the problem? It is a '86 Audi 90 2.2 KV
International Classic Audi Event 28 june 2015
For all Audi's before the "A"
Balendijk, Lommel Belgique.
Re: RPM don't go back to stationary
Message par LaurentV8 » 17 Mai 2017, 11:45
Hello,
Check for a leak in the inlet, or in the vacuum hose, at first...
Message par Mike KV » 17 Mai 2017, 18:14
Hi,
did you check the switch under the throttle body? Does it make a "tic" sound when you move the throttle with your hand?
A leak on the intake will probably result in a bad idle (lower rpm than normal) IMO ;)
Wich sensor did you disconnect?
90cruiser
Message par 90cruiser » 27 Juin 2017, 21:21
It was solved but had a caraccident the day after.
Car is total damaged :(
Message par audipassion » 27 Juin 2017, 21:48
sorry for you
Etienne
